Datasheet Texas Instruments UC2823DWG4 — Даташит
Серия | UC2823 |
Модель | UC2823DWG4 |
Высокоскоростной ШИМ-контроллер 16-SOIC от -25 до 85
High Speed PWM Controller datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 5 авг 2009
Купить UC2823DWG4 на РадиоЛоцман.Цены — от 267 до 509 ₽ 8 предложений от 8 поставщиков Current Mode PWM Controller 1.5A 1000kHz 16Pin SOIC Tube | |||
UC2823DWG4 Texas Instruments | 267 ₽ | ||
UC2823DWG4 Texas Instruments | 290 ₽ | ||
UC2823DWG4 Texas Instruments | 309 ₽ | ||
UC2823DWG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | UC2823DW |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Control Method | Current,Voltage |
Duty Cycle(Max) | 80 % |
Frequency(Max) | 1000 kHz |
Frequency(Min) | 0.1 kHz |
Gate Drive(Typ) | 1.5 A |
Рабочий диапазон температур | от -25 до 85 C |
Package Group | SOIC |
Rating | Catalog |
Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
Topology | Boost,Buck,Flyback,Forward |
UVLO Thresholds On/Off | 9.2/8.4 В |
Vin(Max) | 30 В |
Vin(Min) | 8.4 В |
- U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC2823 (5)
- UC2823DW UC2823DWG4 UC2823DWTR UC2823DWTRG4 UC2823N
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
