Datasheet Texas Instruments UC3846DWTR — Даташит
Серия | UC3846 |
Модель | UC3846DWTR |
ШИМ-контроллер текущего режима 16-SOIC от 0 до 70
UCx846/7 Current Mode PWM Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 4 янв 2016
![]() 51 предложений от 23 поставщиков Чип стабилизации напряжения, Current Mode PWM Controller 500mA 500kHz 16Pin SOIC T/R | |||
UC3846DWTR Texas Instruments | от 153 ₽ | ||
UC3846DWTR Texas Instruments | 161 ₽ | ||
UC3846DWTR Texas Instruments | 177 ₽ | ||
UC3846DWTR Texas Instruments | от 465 ₽ |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | UC3846DW |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 50 % |
Frequency(Max) | 500 kHz |
Gate Drive(Typ) | 0.5 A |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | SOIC |
Rating | Catalog |
Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
Topology | Boost,Flyback,Forward,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 7.7/6.95 В |
Vin(Max) | 40 В |
Vin(Min) | 7 В |
- Modeling Analysis and Compensation of the Current-Mode ConverterPDF, 189 Кб, Файл опубликован: 5 сен 1999
As current-mode conversion increases in popularity several peculiarities associated with fixed-frequency peak-current detecting schemes have surfaced. These include instability above 50% duty cycle a tendency towards subharmonic oscillation non-ideal loop response and an increased sensitivity to noise. This application note attempts to show that the performance of any current-mode converter c - U-93 A New Integrated Circuit for Current Mode ControlPDF, 411 Кб, Файл опубликован: 5 сен 1999
Advantages of current-mode control over conventional PWM approaches to switching power converters include automatic feed-forward automatic symmetry correction inherent current-limiting simple loop-compensation enhanced load-response and the capability for parallel operation. This application note introduces the first control integrated circuit specifically designed for this topology defines - DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICsPDF, 27 Кб, Файл опубликован: 5 сен 1999
The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806
Серия: UC3846 (8)
- UC3846DW UC3846DWG4 UC3846DWTR UC3846DWTRG4 UC3846N UC3846NG4 UC3846Q UC3846QTR
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
