Datasheet Texas Instruments OPA2727AIDRBRG4 — Даташит
Серия | OPA2727 |
Модель | OPA2727AIDRBRG4 |
e-trim™20 МГц, высокоточный КМОП-операционный усилитель 8-SON от -40 до 85
e-trim™ 20MHz, High Precision CMOS Operational Amplifier datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 13 апр 2007
![]() 9 предложений от 9 поставщиков Микросхема Операционный усилитель, e-trim(TM)20MHz, High Precision CMOS Operational Amplifier 8-SON -40℃ to 85℃ | |||
OPA2727AIDRBRG4 Texas Instruments | 30 ₽ | ||
OPA2727AIDRBRG4 Texas Instruments | 76 ₽ | ||
OPA2727AIDRBRG4 Texas Instruments | 104 ₽ | ||
OPA2727AIDRBRG4 | по запросу |
Pin | 8 |
Package Type | DRB |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | NSD |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .88 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Additional Features | Shutdown,Tiny Package |
Архитектура | CMOS |
CMRR(Min) | 86 дБ |
CMRR(Typ) | 94 дБ |
GBW(Typ) | 20 МГц |
Input Bias Current(Max) | 500 pA |
Iq per channel(Max) | 6.5 мА |
Iq per channel(Typ) | 4.3 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.6 uV/C |
Output Current(Typ) | 40 мА |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 30 V/us |
Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 10 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.15 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2727 (7)
- OPA2727AID OPA2727AIDG4 OPA2727AIDR OPA2727AIDRBR OPA2727AIDRBRG4 OPA2727AIDRBT OPA2727AIDRBTG4
