Datasheet Texas Instruments 5962-8869401SA — Даташит
СерияSN54ALS805A
Модель5962-8869401SA
Драйверы NOR Hex с 2 входами 20-CFP от -55 до 125
HXD Co.
5962-8869401SA
Pin20
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)6.92
Length (мм)13.09
Thickness (мм)1.84
Max Height (мм)2.45
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: SN54ALS805A (4)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59628869401SA, 5962 8869401SA
На английском языке: Datasheet Texas Instruments 5962-8869401SA
