Datasheet Texas Instruments UC1706L — Даташит
СерияUC1706
МодельUC1706L
Высокоскоростные драйверы MOSFET с ограничением тока 20-LCCC от -55 до 125
Dual Output Driver datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 2 май 2001
over a 0C to 70C temperature range and, with reduced power, in a hermetically sealed cerdip for -55C to +125C operation....
HXD Co.
UC1706L
3 269 ₽
T-electron
UC1706L
3 549 ₽
UC1706L
LIXINC Electronics
UC1706L
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
МаркировкаUC1706L
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Fall Time40 нс
Input ThresholdTTL
Input VCC(Max)40 В
Input VCC(Min)5 В
Количество каналов2
Package GroupLCCC
Peak Output Current1.5 A
Power SwitchMOSFET
Prop Delay100 нс
RatingMilitary
Rise Time40 нс
Special FeaturesAnalog Shutdown with Latch,Inhibit Circuit,Thermal Shutdown
RoHSSee ti.com
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC1706 (5)
  • Semiconductors > Space & High Reliability > Power Management Products > MOSFET and IGBT Gate Driver
На английском языке: Datasheet Texas Instruments UC1706L
