Datasheet Texas Instruments OPA177FPG4 — Даташит
СерияOPA177
МодельOPA177FPG4
Прецизионный операционный усилитель 8-PDIP
Precision Operational Amplifier datasheet
PDF, 296 Кб, Файл опубликован: 27 сен 2000
Микросхема Буферный усилитель, IC OPAMP GP 600kHz 8DIP
OPA177FPG4
82 ₽
T-electron
OPA177FPG4
124 ₽
OPA177FPG4
481 ₽
IC Home
OPA177FPG4
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA177FP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)115 дБ
CMRR(Typ)140 дБ
GBW(Typ)0.6 МГц
Input Bias Current(Max)2000 pA
Iq per channel(Max)2 мА
Iq per channel(Typ)1.3 мА
Количество каналов1
Offset Drift(Typ)0.1 uV/C
Output Current(Typ)22 мА
Package GroupPDIP
Rail-to-RailOut
Slew Rate(Typ)0.3 V/us
Total Supply Voltage(Min)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.025 мВ
  • Diode-Based Temperature Measurement
    PDF, 44 Кб, Файл опубликован: 27 сен 2000
    Diodes are frequently used as temperature sensors in a wide variety of moderate-precision temperature measurement applications. The relatively high temperature coefficient of about -2mV/В°C is fairly linear. To make a temperature measurement system with a diode requires excitation, offsetting, and amplification. The circuitry can be quite simple. This Bulletin contains a collection of circuits
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA177FPG4
