Datasheet Texas Instruments SN74LVT162245ADLR — Даташит
СерияSN74LVT162245A
МодельSN74LVT162245ADLR
16-битные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями 48-SSOP от -40 до 85
SN54LVT162245A, SN74LVT162245A datasheet
PDF, 719 Кб, Версия: D, Файл опубликован: 18 ноя 2006
28 предложений от 14 поставщиков
Микросхема Логический контроллер, 3.3V ABT 16Bit Bus Transceivers With 3-State Outputs 48-SSOP -40℃ to 85℃
T-electron
SN74LVT162245ADLR
83 ₽
IC Home
SN74LVT162245ADLR
92 ₽
SN74LVT162245ADLR
от 198 ₽
ТаймЧипс
SN74LVT162245ADLR
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLVT162245A
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.7 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVT162245ADLR
