Datasheet Texas Instruments UCC28070PWG4 — Даташит
Серия | UCC28070 |
Модель | UCC28070PWG4 |
Двухфазный контроллер CCM PFC с чередованием 20-TSSOP от -40 до 125
UCC28070 Interleaving Continuous Conduction Mode PFC Controller datasheet
PDF, 1.9 Мб, Версия: F, Файл опубликован: 18 апр 2016
Купить UCC28070PWG4 на РадиоЛоцман.Цены — от 147 до 557 ₽ 10 предложений от 10 поставщиков Power Factor Correction CONTRLR 20mA 30kHz to 300kHz 20Pin TSSOP Tube | |||
UCC28070PWG4 Texas Instruments | 147 ₽ | ||
UCC28070PWG4 Texas Instruments | 212 ₽ | ||
UCC28070PWG4 Texas Instruments | 557 ₽ | ||
UCC28070PWG4 Texas Instruments | по запросу |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 70 |
Carrier | TUBE |
Маркировка | 28070 |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Control Method | CCM |
Device Type | Interleaved PFC |
Operating Supply Current | 20 мА |
Operating Supply(Max) | 21 В |
Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Peak Output Sink Current Gate Drive | 0.75 A |
Peak Output Source Current Gate Drive | -0.75 A |
Practical Operating Frequency(Max) | 0.3 МГц |
Rating | Catalog |
Special Features | > 750W Applications,Average Current Mode,Interleaved,OVP |
Startup Current | 20 мА |
UVLO Thresholds On/Off | 10.2/9.2 В |
- Evaluation Modules & Boards: UCC28070EVM
UCC28070 Evaluation module
- UCC28070 300W Interleaved PFC Pre-regulator Design Review (Rev. B)PDF, 753 Кб, Версия: B, Файл опубликован: 8 июл 2010
In higher power applications to utilize the full line power and reduce line current harmonics PFC Pre-regulators are generally required. In these high power applications interleaving PFC stages can reduce inductor volume and reduce input and output capacitor ripple current. This results in smaller overall magnetic volume and filter capacitor volume increasing the converters overall power density. - UCC28070 Implement Bridgeless PFC Pre-Regulator DesignPDF, 739 Кб, Файл опубликован: 18 июн 2009
Bridgeless power factor correction (PFC) topology is attracting attention as a means of satisfying the new high-efficiency requirements. This application report reviews the UCC28070 and its design considerations for bridgeless PFC. It present a bridgeless solution that is relatively easy to implement in that it does not require any additional circuitry for current sensing and that the operation re
Серия: UCC28070 (6)
- UCC28070DW UCC28070DWR UCC28070PW UCC28070PWG4 UCC28070PWR UCC28070PWRG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
