Datasheet Texas Instruments TPS62140RGTR — Даташит
Серия | TPS62140 |
Модель | TPS62140RGTR |
3–17V 2A Step-Down Converter with DCS-Control in 3x3 QFN package 16-VQFN -40 to 125
TPS6214x 3-V to 17-V 2-A Step-Down Converter in 3 Г— 3 QFN Package datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 12 сен 2016
![]() 64 предложений от 24 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — постоянного тока коммутирующие | |||
TPS62140RGTR Texas Instruments | 77 ₽ | ||
TPS62140RGTR Texas Instruments | 85 ₽ | ||
TPS62140RGTR Texas Instruments | по запросу | ||
Pin | 16 |
Package Type | RGT |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | QTZ |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Constant on-time (COT) |
Duty Cycle(Max) | 100 % |
Iout(Max) | 2 A |
Iq(Typ) | 0.017 мА |
Package Group | VQFN |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking,UVLO Fixed,Voltage Margining |
Switching Frequency(Max) | 2500 kHz |
Switching Frequency(Min) | 1250 kHz |
Switching Frequency(Typ) | 2500 kHz |
Тип | Converter |
Vin(Max) | 17 В |
Vin(Min) | 3 В |
Vout(Max) | 6.3 В |
Vout(Min) | 0.9 В |
- Evaluation Modules & Boards: TPS62140EVM-505
Evaluation Module for TPS62140 a 2-A, synchronous, step-down converter in a 3x3-mm, 16-pin QFN
- Using the TPS62150 in a Split Rail TopologyPDF, 429 Кб, Файл опубликован: 26 мар 2014
- Voltage Margining Using the TPS62130PDF, 79 Кб, Файл опубликован: 15 дек 2011
Voltage margining is a means of verifying the robustness of a product by intentionally adjusting its supply voltages to their limits and then evaluating the product’s performance to ensure that it still meets its specifications at the power supply’s extremes. The TPS62130 synchronous step-down dc-dc converter features an integrated output voltage scaling function that allows for +5% margining by u - TPS62130A Differences to TPS62130PDF, 247 Кб, Файл опубликован: 2 апр 2014
- Step-Down LED Driver With Dimming With the TPS621-Family and TPS821-Family (Rev. A)PDF, 284 Кб, Версия: A, Файл опубликован: 28 июн 2017
- Feedforward Capacitor to Improve Stability and Bandwidth of TPS621/821-Family (Rev. A)PDF, 720 Кб, Версия: A, Файл опубликован: 28 июн 2017
- Sequencing and Tracking With the TPS621-Family and TPS821-Family (Rev. A)PDF, 210 Кб, Версия: A, Файл опубликован: 28 июн 2017
- Step-Down Converter with Cable Voltage Drop CompensationPDF, 441 Кб, Файл опубликован: 26 июн 2014
- Step-Down Converter With Input Overvoltage ProtectionPDF, 274 Кб, Файл опубликован: 4 сен 2014
TPS62130 Step-Down Converter with Input Overvoltage Protection - Optimizing the TPS62130/40/50/60 Output Filter (Rev. A)PDF, 336 Кб, Версия: A, Файл опубликован: 15 июл 2015
- Using the TPS6215x in an Inverting Buck-Boost Topology.. (Rev. C)PDF, 738 Кб, Версия: C, Файл опубликован: 19 дек 2012
- How to Measure the Control Loop of DCS-Control Devices (Rev. A)PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
- High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitionsPDF, 605 Кб, Файл опубликован: 25 июл 2013
- Understanding frequency variation in the DCS-Control(TM) topologyPDF, 224 Кб, Файл опубликован: 30 окт 2015
- Design considerations for a resistive feedback divider in a DC/DC converterPDF, 393 Кб, Файл опубликован: 26 апр 2012
- Five steps to a great PCB layout for a step-down converterPDF, 162 Кб, Файл опубликован: 29 янв 2015
- Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Testing tips for applying external power to supply outputs without an input voltPDF, 110 Кб, Файл опубликован: 24 окт 2016
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- QFN and SON PCB Attachment (Rev. B)PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
When performing measurements on DC-DC converters using pulse frequency modulation(PFM)or any power save mode proper care must be taken to ensure that the measurements are accurate. An accurate PFM mode efficiency measurement is critical for systems which require high efficiency at low loads such as in smart home systems tablets wearables and metering. - Powering the MSP430 from a High Voltage Input using the TPS62122 (Rev. C)PDF, 330 Кб, Версия: C, Файл опубликован: 12 янв 2012
Серия: TPS62140 (2)
- TPS62140RGTR TPS62140RGTT
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
