Datasheet Texas Instruments SN74LVT125PWLE — Даташит
СерияSN74LVT125
МодельSN74LVT125PWLE
Буферы с четырьмя шинами ABT, 3,3 В, с выходами с 3 состояниями, 14-TSSOP от -40 до 85
SN74LVT125 datasheet
PDF, 673 Кб, Версия: F, Файл опубликован: 13 окт 2003
8 предложений от 5 поставщиков
Буферы и линейные аппаратные драйверы 3.3V ABT Quad Bus Buff W/3-St Otpt
SN74LVT125PWLE
от 68 ₽
Элитан
SN74LVT125PWLE
103 ₽
SN74LVT125PWLE
МосЧип
SN74LVT125PWLE
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementSN74LVT125PWR
Replacement CodeS
Approx. Price (US$)0.52 | 1ku
Bits(#)4
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.007
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-32/64
Тип выходаLVTTL
Package GroupTSSOP
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)(V)3.6
VCC(Min)(V)2.7
Voltage(Nom)(V)3.3
tpd @ Nom Voltage(Max)(ns)4
RoHSНе совместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
На английском языке: Datasheet Texas Instruments SN74LVT125PWLE
