Datasheet Texas Instruments UC1825L883B — Даташит
СерияUC1825
МодельUC1825L883B
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 24 фев 2004
HIGH SPEED PWM CONTROLLER 20-LCC / Regulator Output DC-DC Controller IC
T-electron
UC1825L883B
4 269 ₽
UC1825L883B
4 592 ₽
Зенер
Россия и страны ТС
UC1825L883B DM: 5962-87681012A
12 145 ₽
Allelco
UC1825L/883B
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаUC1825L/87681012A883B5962-
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
Control MethodCurrent
Duty Cycle(Max)80 %
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)8.4 В
RoHSSee ti.com
  • U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power Supply
    PDF, 298 Кб, Файл опубликован: 5 сен 1999
    The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U
  • U-111 Practical Considerations in Current Mode Power Supplies
    PDF, 787 Кб, Файл опубликован: 5 сен 1999
    This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1825L883B
