Datasheet Texas Instruments TPS77401DGKG4 — Даташит
Серия | TPS774 |
Модель | TPS77401DGKG4 |
LDO-регуляторы 250 мА с Power Good 8-VSSOP от -40 до 125
250-mA LDO Regulators With 8-pin MSOP Packaging datasheet
PDF, 874 Кб, Версия: E, Файл опубликован: 22 мар 2002
Купить TPS77401DGKG4 на РадиоЛоцман.Цены — от 77 до 206 ₽ 8 предложений от 8 поставщиков LDO Regulator Pos 1.5V to 5.5V 0.25A 8Pin VSSOP Tube | |||
TPS77401DGKG4 Texas Instruments | 77 ₽ | ||
TPS77401DGKG4 Texas Instruments | 119 ₽ | ||
TPS77401DGKG4 Texas Instruments | 206 ₽ | ||
TPS77401DGKG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 80 |
Carrier | TUBE |
Маркировка | AGO |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Точность | 2 % |
Fixed Output Options | 1.5,1.8,2.8,3.3,5 В |
Iout(Max) | 0.25 A |
Iq(Typ) | 0.09 мА |
Noise | 55 uVrms |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 25 дБ |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Power Good |
Thermal Resistance ОёJA | 243 В°C/W |
Vdo(Typ) | 200 мВ |
Vin(Max) | 10 В |
Vin(Min) | 2.7 В |
Vout(Max) | 5.5 В |
Vout(Min) | 1.5 В |
- Powering OMAP3 With TPS6235x: Design-In GuidePDF, 296 Кб, Файл опубликован: 3 дек 2008
The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution.
Серия: TPS774 (12)
