Datasheet Texas Instruments ISO7341FCQDWRQ1 — Даташит
Серия | ISO7341-Q1 |
Модель | ISO7341FCQDWRQ1 |
Автомобильный, маломощный, четырехканальный цифровой изолятор 3/1, 16-SOIC от -40 до 125
ISO734x-Q1 Robust EMC, Low-Power, Quad-Channel Digital Isolators datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 30 май 2017
Купить ISO7341FCQDWRQ1 на РадиоЛоцман.Цены — от 198 до 908 ₽ 25 предложений от 11 поставщиков Digital Isolator CMOS 4CH 25Mbps Automotive 16Pin SOIC T/R | |||
ISO7341FCQDWRQ1 Texas Instruments | 198 ₽ | ||
ISO7341FCQDWRQ1 Texas Instruments | 209 ₽ | ||
ISO7341FCQDWRQ1 Texas Instruments | 279 ₽ | ||
ISO7341FCQDWRQ1 Texas Instruments | от 908 ₽ |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | ISO7341FCQ |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Data Rate(Max) | 25 Mbps |
Default Output | Low |
Forward/Reverse Channels | 3/1 |
Integrated Isolated Power | No |
Isolation Rating | 3000 Vrms |
Количество каналов | 4 |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Время задержки распространения | 31 нс |
Propagation Delay(Typ) | 31 нс |
Rating | Automotive |
Surge Voltage Rating | 6000 Vpk |
VCC(Max) | 5 В |
VCC(Min) | 3.3 В |
- Evaluation Modules & Boards: ISO7342CEVM
ISO7342CEVM Quad-Channel, Digital Isolator Evaluation Module
- Shelf-Life Evaluation of Lead-Free Component FinishesPDF, 1.3 Мб, Файл опубликован: 24 май 2004
The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a - Isolation GlossaryPDF, 52 Кб, Файл опубликован: 27 окт 2014
- Digital Isolator Design Guide (Rev. A)PDF, 487 Кб, Версия: A, Файл опубликован: 4 ноя 2014
Серия: ISO7341-Q1 (4)
- ISO7341CQDWQ1 ISO7341CQDWRQ1 ISO7341FCQDWQ1 ISO7341FCQDWRQ1
- Semiconductors > Isolation > Digital Isolators
