Datasheet Texas Instruments LM57CISDX-10/NOPB — Даташит
Серия | LM57 |
Модель | LM57CISDX-10/NOPB |
В±0.7В°C Temperature Sensor with Resistor-Programmable Temperature Switch 8-WSON -50 to 150
LM57 Resistor-Programmable Temperature Switch and Analog Temperature Sensor datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 15 июл 2015
![]() 8 предложений от 8 поставщиков Датчики Температуры, Board Mount Temperature Sensors 0.7C Temperature Sensor with Resistor-Programmable Temperature Switch 8-WSON -50 to 150 | |||
LM57CISDX-10/NOPB Texas Instruments | 54 ₽ | ||
LM57CISDX-10/NOPB Texas Instruments | 66 ₽ | ||
LM57CISDX-10/NOPB Texas Instruments | 87 ₽ | ||
LM57CISDX-10/NOPB Texas Instruments | по запросу |
Pin | 8 |
Package Type | NGR |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 4500 |
Carrier | LARGE T&R |
Маркировка | 57C9 |
Width (мм) | 2.5 |
Length (мм) | 2.5 |
Thickness (мм) | .8 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
# Comparators | 1 |
Accuracy Over Temp Range(Max) | 1.5 C |
Interface | Analog Output,Switch |
Рабочий диапазон температур | от -50 до 150 C |
Тип выхода | Open Drain,Push Pull |
Package Group | WSON |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Rating | Catalog |
Sensor Gain | -5.2 to -12.9 mV/Deg C |
SetPoint Type | Resistor Programmable |
SetPoint Value | -40 to 150 deg C |
Special Features | Built-in Hysteresis,Hysteresis (5В°C or 10В°C),Temperature Sensor and Switch,Trip Test |
Supply Current(Typ) | 24 uA |
Supply Voltage(Max) | 5.5 В |
Supply Voltage(Min) | 2.4 В |
- Evaluation Modules & Boards: LM57EVM
Evalution Module for Analog Temperature Sensor
- AN-1984 LM57 Temperature Switch vs Thermistors (Rev. C)PDF, 83 Кб, Версия: C, Файл опубликован: 1 май 2013
This application report compares the system design and performance advantages of sensing with TexasInstruments LM57 CMOS integrated circuit sensor as compared to a thermal-resistant (thermistor) sensorcircuit.
Серия: LM57 (12)
- Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
LM57CISDX10/NOPB, LM57CISDX 10/NOPB
