Datasheet Texas Instruments CD74ACT00M — Даташит
Серия | CD74ACT00 |
Модель | CD74ACT00M |
Четырехвходовые вентили NAND с 2 входами 14-SOIC от -55 до 125
Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 969 Кб, Версия: B, Файл опубликован: 12 июн 2002
Купить CD74ACT00M на РадиоЛоцман.Цены — от 11 до 122 ₽ 32 предложений от 24 поставщиков 74ACT CMOS, SMD, 74ACT00, SOIC14; Logic IC Function:Quadruple 2-Input NAND Gate; Logic IC Family:ACT; Logic IC Base Number:7400; Current, Output Max:24mA;... | |||
CD74ACT00M Harris | 11 ₽ | ||
CD74ACT00M96 Texas Instruments | 12 ₽ | ||
CD74ACT00M Texas Instruments | 94 ₽ | ||
CD74ACT00M96 Texas Instruments | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | ACT00M |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 90 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ACT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 9.5 нс |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT00 (7)
- Semiconductors > Logic > Gate > NAND Gate
