Datasheet Texas Instruments TMS320VC5420ZGU200 — Даташит
Серия | TMS320VC5420 |
Модель | TMS320VC5420ZGU200 |
Цифровой сигнальный процессор 144-BGA MICROSTAR
TMS320VC5420 Fixed-Point Digital Signal Processor datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 22 окт 2008
Купить TMS320VC5420ZGU200 на РадиоЛоцман.Цены — от 7 688 до 19 894 ₽ 9 предложений от 9 поставщиков Интегральные микросхемы Встроенные микросхемы - Цифровые сигнальные процессоры (ЦСП) | |||
TMS320VC5420ZGU200 Texas Instruments | 7 688 ₽ | ||
TMS320VC5420ZGU200 Texas Instruments | 8 781 ₽ | ||
TMS320VC5420ZGU200 Texas Instruments | 9 770 ₽ | ||
TMS320VC5420ZGU200 Texas Instruments | 9 820 ₽ |
Pin | 144 | 144 |
Package Type | ZGU | ZGU |
Industry STD Term | BGA MICROSTAR | BGA MICROSTAR |
JEDEC Code | S-PBGA-N | S-PBGA-N |
Маркировка | 200 | DVC5420ZGU |
Width (мм) | 12 | 12 |
Length (мм) | 12 | 12 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .8 | .8 |
Max Height (мм) | 1.4 | 1.4 |
- Evaluation Modules & Boards: TMDSDSK5416
TMS320C5416 DSP Starter Kit (DSK)
- Interfacing the PCI2040 to the TMS320VC5420 DSPPDF, 86 Кб, Файл опубликован: 28 июн 2000
This application note describes how system designers can interface the TMS320VC5420 16-bit HPI (C5420) to the PCI bus, using the TMS320C6x HPI (C6x) mode interface on the PCI2040 PCI-to-DSP bridge. The note specifies two modes for mapping the C5420 to host memory, depending on the number of C5420s. The note also describes both hardware and software considerations, provides an example schematic, an - TPS6010x/TPS6011x Charge Pump (Rev. A)PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
Серия: TMS320VC5420 (6)
- TMS320C5420GGUA200 TMS320C5420GGUR200 TMS320C5420PGEA200 TMS320VC5420GGU200 TMS320VC5420PGE200 TMS320VC5420ZGU200
- Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
