Datasheet Texas Instruments LM3S1C21-IQC80-A2T — Даташит
СерияLM3S1C21
МодельLM3S1C21-IQC80-A2T
Микроконтроллер Stellaris LM3S 100-LQFP от -40 до 85
Stellaris LM3S1C21 Microcontroller Data Sheet datasheet
PDF, 5.8 Мб, Версия: C, Файл опубликован: 3 июл 2014
LM3S1C21-IQC80-A2T
66 ₽
LM3S1C21-IQC80-A2T
IC Home
LM3S1C21-IQC80-A2T
T-electron
LM3S1C21-IQC80-A2T
Pin100100
Package TypePZPZ
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаLM3S1C21IQC80
Width (мм)1414
Length (мм)1414
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S1C21IQC80A2T, LM3S1C21 IQC80 A2T
На английском языке: Datasheet Texas Instruments LM3S1C21-IQC80-A2T
