Datasheet Texas Instruments LM89-1CIMM/NOPB — Даташит
Серия | LM89 |
Модель | LM89-1CIMM/NOPB |
В±0.75В°C Remote and Local Temperature Sensor with SMBus Interface 8-VSSOP 0 to 125
LM89 В±0.75В°C Accurate, Remote Diode And Local Digital Temperature Sensor With Two-Wire Interface datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 23 июн 2014
Купить LM89-1CIMM/NOPB на РадиоЛоцман.Цены — от 98 до 485 ₽ 17 предложений от 12 поставщиков Температурные датчики для монтажа на плате | |||
LM89-1CIMM/NOPB Texas Instruments | от 98 ₽ | ||
LM89-1CIMM/NOPB National Semiconductor | 126 ₽ | ||
LM89-1CIMM/NOPB Texas Instruments | 196 ₽ | ||
LM89-1CIMM-NOPB Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | SMALL T&R |
Маркировка | T19C |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Interface | I2C,SMBus |
Local Sensor Accuracy(Max) | 3 +/- C |
Рабочий диапазон температур | от 0 до 125 C |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rating | Catalog |
Remote Channel | 1 |
Remote Diode Temp Range for Listed Accuracy | 80 C |
Remote Sensor Accuracy(Max) | 0.75 +/- C |
Remote Sensor Correction | Offset Correction Register |
Remote Temp Resolution(Max) | 11 bits |
Special Features | Programmable Alert,Programmable conversion rate,Shutdown |
Supply Current(Typ) | 800 uA |
Supply Voltage(Max) | 3.6 В |
Supply Voltage(Min) | 3 В |
Temp Resolution(Max) | 8 bits |
Серия: LM89 (8)
- Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
LM891CIMM/NOPB, LM89 1CIMM/NOPB
