Datasheet Texas Instruments LM22679QTJ-5.0/NOPB — Даташит
СерияLM22679-Q1
МодельLM22679QTJ-5.0/NOPB
ПРОСТОЙ ПЕРЕКЛЮЧАТЕЛЬ 5 А, понижающий стабилизатор напряжения с регулируемым плавным пуском и ограничением тока 7-TO-263 от -40 до 125
LM22679/-Q1 42-V, 5-A SIMPLE SWITCHERВ® Step-Down Voltage Regulator With Features datasheet
PDF, 1.2 Мб, Версия: L, Файл опубликован: 4 ноя 2014
16 предложений от 9 поставщиков
LM22679QTJ-5.0/NOPB
239 ₽
LM22679QTJ-5.0/NOPB
377 ₽
LM22679QTJ-5.0/NOPB
397 ₽
LM22679QTJ-5.0/NOPB
Pin77
Package TypeNDRNDR
Industry STD TermTO-263TO-263
JEDEC CodeR-MSFM-LR-MSFM-L
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаLM22679QTJ-5.0
Width (мм)9.859.85
Length (мм)10.1610.16
Thickness (мм)22
Pitch (мм)1.271.27
Max Height (мм)2.252.25
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)5 A
Iq(Typ)3.4 мА
Package GroupTO-263
RatingAutomotive
Regulated Outputs1
Special FeaturesAdjustable Current Limit
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)1.285 В
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
LM22679QTJ5.0/NOPB, LM22679QTJ 5.0/NOPB
На английском языке: Datasheet Texas Instruments LM22679QTJ-5.0/NOPB
Публикации по теме
