Datasheet Texas Instruments CD54HCT02F3A — Даташит
Серия | CD54HCT02 |
Модель | CD54HCT02F3A |
Высокоскоростная КМОП-логика с двумя входами, вентили ИЛИ-НЕ, 14-CDIP, от -55 до 125
CD54HC02, CD74HC02, CD54HCT02, CD74HCT02 datasheet
PDF, 717 Кб, Версия: C, Файл опубликован: 21 авг 2003
![]() 20 предложений от 17 поставщиков Микросхема Логический чип, NOR Gate 4Element 2IN CMOS 14Pin CDIP Tube | |||
CD54HCT02F3A(5962-8975101CA) Texas Instruments | от 58 ₽ | ||
CD54HCT02F3A Texas Instruments | 610 ₽ | ||
CD54HCT02F3A Texas Instruments | 1 202 ₽ |
Pin | 14 | 14 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | CD54HCT02F3A | 5962-8975101CA |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 19.56 | 19.56 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 4 |
F @ Nom Voltage(Max) | 25 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 4/-4 мА |
Тип выхода | CMOS |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | HCT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 32 нс |
RoHS | See ti.com |
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT02 (3)
- 5962-8975101CA CD54HCT02F CD54HCT02F3A
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
