Datasheet Texas Instruments BQ24108RHLR — Даташит
Серия | BQ24108 |
Модель | BQ24108RHLR |
Автономное синхронное импульсное литий-ионное зарядное устройство с полевым транзистором 2 А в QFN-20, 1-элементный 20-VQFN от -40 до 85
bq241xx Synchronous Switched-Mode, Li-Ion and Li-Polymer Charge-Management IC With Integrated Power FETs (bqSWITCHERв„ў) datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 30 ноя 2015
Купить BQ24108RHLR на РадиоЛоцман.Цены — от 1.96 до 748 ₽ 32 предложений от 14 поставщиков Battery Charge Management Standalone Synchronous Switch-mode Li-Ion Charger w/2A FET in QFN-20, 1-Cell Switch Mode Charger Li-Ion/Li-Pol/NiCD/NiMH 150mA to 2000mA 4.2V... | |||
BQ24108RHLR Texas Instruments | от 1.96 ₽ | ||
BQ24108RHLR Texas Instruments | от 161 ₽ | ||
BQ24108RHLR Texas Instruments | по запросу | ||
Pin | 20 |
Package Type | RHL |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | CIU |
Width (мм) | 3.5 |
Length (мм) | 4.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Absolute Vin (safety rating)(Max)( | 20 В |
Battery Charge Voltage(Max) | 4.2 В |
Battery Charge Voltage(Min) | 4.2 В |
Cell Chemistry | Li-Ion/Li-Polymer |
Charge Current(Max) | 2 A |
Control Interface | Standalone (RC-Settable) |
Control Topology | Switch-Mode Buck |
Number of Series Cells | 1 |
Operating Vin(Max) | 16 В |
Operating Vin(Min) | 4.35 В |
Package Group | VQFN |
Package Size: mm2:W x L | 20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG |
Special Features | Integrated FET,Temp Monitoring (Thermistor Pin) |
USB Feature | N/A |
- Power Dissipation Analysis & Circuit Design for Sync Switching Battery ChargerPDF, 402 Кб, Файл опубликован: 31 май 2005
The bqSWITCHER(TM) (bq24100/03/05/08/13/15) is a highly integrated, switch-mode, Li-ion and Li-polymer battery charger IC. With two power MOSFETs, the gate drivers, and the controller fully integrated in the chip, the circuit design as well as the PCB layout has been appreciably simplified. However, it is still important to have a good understanding of the charger circuit design, layout principles - Implementations of Battery Charger and Power-Path Mgmt System Using bq241xxPDF, 752 Кб, Файл опубликован: 6 июн 2006
This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed. - Drive High Current LEDsPDF, 437 Кб, Файл опубликован: 25 янв 2007
This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24108 (2)
- BQ24108RHLR BQ24108RHLRG4
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
