Datasheet Texas Instruments SN74LVTH543PW — Даташит
Серия | SN74LVTH543 |
Модель | SN74LVTH543PW |
Восьмеричные регистровые приемопередатчики ABT 3,3 В с выходами с 3 состояниями 24-TSSOP от -40 до 85
SN54LVTH543, SN74LVTH543 datasheet
PDF, 872 Кб, Версия: F, Файл опубликован: 13 окт 2003
![]() 35 предложений от 14 поставщиков Интегральные микросхемы Логические микросхемы - Буферы, Приемники, Приемопередатчики | |||
SN74LVTH543PW Texas Instruments | 51 ₽ | ||
SN74LVTH543PW Texas Instruments | 73 ₽ | ||
SN74LVTH543PW Texas Instruments | 170 ₽ | ||
SN74LVTH543PW Texas Instruments | по запросу |
Pin | 24 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 60 |
Carrier | TUBE |
Маркировка | LXH543 |
Width (мм) | 4.4 |
Length (мм) | 7.8 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 160 Mhz |
ICC @ Nom Voltage(Max) | 0.005 мА |
Output Drive (IOL/IOH)(Max) | -32/64 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVT |
VCC(Max) | 3.6 В |
VCC(Min) | 2.7 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 3.7 нс |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed. - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVTH543 (8)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
