Datasheet Texas Instruments ADS1213U/1K — Даташит
СерияADS1213
МодельADS1213U/1K
22-битный аналого-цифровой преобразователь 24-SOIC от -40 до 85
ADS1212, ADS1213: 22-Bit Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 18 фев 2004
Микросхема Преобразователь AD, ADC Single Delta-Sigma 6.25KSPS 22Bit Serial 24Pin SOIC T/R
ADS1213U/1K
926 ₽
ADS1213U/1K
3 854 ₽
ИМЭК
Россия и страны ТС
ADS1213U/1K
3 940 ₽
ADS1213U/1K
Pin24
Package TypeDW
Package QTY1000
МаркировкаADS1213U
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Calibration Routines and Register Value Generation for the ADS121x Series
    PDF, 298 Кб, Файл опубликован: 19 июн 2003
    In order to achieve the best possible performance, offset and gain can be often be calibrated in high-resolution analog-to-digital converters (ADCs). Changes in temperature, PGA gain, power supply voltage, or most importantly, decimation ratio can influence the accuracy of measurement. This application note explains how the calibration routines work and how to generate values for the full-scale re
  • Inputs Currents for High-Resolution ADCs
    PDF, 127 Кб, Файл опубликован: 6 мар 2003
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
На английском языке: Datasheet Texas Instruments ADS1213U/1K
