Datasheet Texas Instruments SN74LVT245BDBR — Даташит
СерияSN74LVT245B
МодельSN74LVT245BDBR
Приемопередатчики восьмеричной шины ABT 3,3 В с выходами с 3 состояниями 20-SSOP от -40 до 85
SN74LVT245B datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 9 сен 2003
36 предложений от 20 поставщиков
Микросхема Логический контроллер, TEXAS INSTRUMENTS SN74LVT245BDBR Transceiver, 74LVT245, 2.7V to 3.6V, SSOP-20
SN74LVT245BDBR
от 12 ₽
SN74LVT245BDBR
Yageo
ЗУМ-СМД
SN74LVT245BDBR
SN74LVT245BDBR
Pin20
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаLX245B
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupSSOP
Package Size: mm2:W x L20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.5 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVT245BDBR
