Datasheet Texas Instruments CD74HC157MT — Даташит
Серия | CD74HC157 |
Модель | CD74HC157MT |
Высокоскоростные мультиплексоры CMOS Logic Quad с 2 входами 16-SOIC от -55 до 125
CD54/74HC157, CD54/74HCT157, CD54/74HC158, CD54/74HCT158 datasheet
PDF, 449 Кб, Версия: C, Файл опубликован: 13 окт 2003
![]() 19 предложений от 14 поставщиков Микросхема Логический контроллер, Multiplexer 1Element CMOS 8IN 16Pin SOIC T/R | |||
CD74HC157MT Texas Instruments | от 8.55 ₽ | ||
CD74HC157MT Texas Instruments | от 22 ₽ | ||
CD74HC157MT Texas Instruments | от 38 ₽ | ||
CD74HC157MT Texas Instruments | 46 ₽ |
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | HC157M |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Полоса частот | 28 МГц |
Bits | 2 |
Количество каналов | 4 |
Configuration | 2:1 |
Digital input leakage(Max) | 5 uA |
ESD Charged Device Model | 0.75 kV |
ESD HBM | 2 kV |
F @ Nom Voltage(Max) | 28 Mhz |
Function | Encoder/Multiplexer |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
Тип | Standard |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 10 нс |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC157 (8)
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
