Datasheet Texas Instruments 74ALVTHR16245GRG4 — Даташит
Серия | SN74ALVTHR16245 |
Модель | 74ALVTHR16245GRG4 |
16-битный шинный приемопередатчик 2,5 В/3,3 В с выходами с 3 состояниями 48-TSSOP от -40 до 85
SN54ALVTHR16245, SN74ALVTHR16245 datasheet
PDF, 939 Кб, Версия: D, Файл опубликован: 2 дек 2002
![]() 9 предложений от 9 поставщиков Микросхема Логический контроллер, 2.5V/3.3V 16Bit Bus Transceiver With 3-State Outputs 48-TSSOP -40℃ to 85℃ | |||
74ALVTHR16245GRG4 Texas Instruments | 82 ₽ | ||
74ALVTHR16245GRG4 Texas Instruments | 91 ₽ | ||
SN74ALVTHR16245GRG4 Texas Instruments | по запросу | ||
74ALVTHR16245GRG4 | по запросу |
Pin | 48 |
Package Type | DGG |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | ALVTHR16245 |
Width (мм) | 6.1 |
Length (мм) | 12.5 |
Thickness (мм) | 1.15 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 250 Mhz |
ICC @ Nom Voltage(Max) | 5 мА |
Output Drive (IOL/IOH)(Max) | -12/12 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ALVT |
VCC(Max) | 3.6 В |
VCC(Min) | 2.3 В |
Voltage(Nom) | 2.5,3.3 В |
tpd @ Nom Voltage(Max) | 4.3,3.7 нс |
- Advanced Low-Voltage TechnologyPDF, 59 Кб, Файл опубликован: 27 июл 1999
ALVT, the advanced low-voltage logic family, offers high-performance BiCMOS devices that are functional at 3.3-V and 2.5-V V sub CC and have low propagation delay, low static-power consumption, and 64 mA current drive. Other features include 5-V tolerance; auto3-state; bus hold; partial power down, hot insertion, and live insertion; and excellent simultaneous-switching and output-skew performance. - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Many telecom and networking applications require that cards be inserted and extracted from a live backplane without interrupting data or damaging components. To achieve this interface terminals of the card must be electrically isolated from the bus system during insertion or extraction from the backplane. To facilitate this Texas Instruments provides bus-interface and logic devices with features - TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: SN74ALVTHR16245 (7)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
