Datasheet Texas Instruments UC3906DWTR — Даташит
Серия | UC3906 |
Модель | UC3906DWTR |
Зарядное устройство для линейных свинцово-кислотных аккумуляторов 16-SOIC от -20 до 70
Sealed Lead-Acid Battery Charger datasheet
PDF, 4.3 Мб, Версия: C, Файл опубликован: 23 май 2005
![]() 22 предложений от 15 поставщиков TEXAS INSTRUMENTS UC3906DWTR Battery Charger for Lead Acid battery, 40V input, 2A charge, SOIC-16 | |||
UC3906DWTR Texas Instruments | 32 ₽ | ||
UC3906DWTR Texas Instruments | от 198 ₽ | ||
UC3906DWTR Texas Instruments | 209 ₽ | ||
UC3906DWTR Texas Instruments | 982 ₽ |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | UC3906DW |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | BQ24450DWTR |
Replacement Code | F |
- U-104 Improved Charging Methods for Lead-Acid Batteries Using the UC3906PDF, 331 Кб, Файл опубликован: 5 сен 1999
This application note describes the operation and application of the UC3906 sealed lead-acid battery-charger IC. Several charging circuits using this IC are described, along with expected improvements in battery performance. This note also discusses uses for the many auxiliary functions of the part. - U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC3906 (10)
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
