Datasheet Texas Instruments SN74LVC10APWR — Даташит
Серия | SN74LVC10A |
Модель | SN74LVC10APWR |
Тройной логический элемент положительного NAND с 3 входами 14-TSSOP от -40 до 125
SN74LVC10A datasheet
PDF, 996 Кб, Версия: O, Файл опубликован: 27 июл 2005
![]() 27 предложений от 19 поставщиков Микросхема Логический чип, NAND Gate 3Element 3IN CMOS 14Pin TSSOP T/R | |||
SN74LVC10APWRE4 Texas Instruments | 8.69 ₽ | ||
SN74LVC10APWR Texas Instruments | 35 ₽ | ||
SN74LVC10APWR | от 81 ₽ | ||
SN74LVC10APWR Texas Instruments | по запросу |
Pin | 14 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LC10A |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 3 |
F @ Nom Voltage(Max) | 150 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 10.6,7.8,5.8,4.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC10A (16)
- Semiconductors > Logic > Gate > NAND Gate
