Datasheet Texas Instruments SN74LVC126ADR — Даташит
Серия | SN74LVC126A |
Модель | SN74LVC126ADR |
Четверной буферный вентиль шины с выходами с 3 состояниями, 14-SOIC, от -40 до 125
SN74LVC126A Quadruple Bus Buffer Gate With 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: S, Файл опубликован: 6 фев 2017
![]() 35 предложений от 16 поставщиков Микросхема Логический контроллер, Buffer/Line Driver 4CH Non-Inverting 3-ST CMOS 14Pin SOIC T/R | |||
SN74LVC126ADR Texas Instruments | 5.71 ₽ | ||
SN74LVC126ADR Texas Instruments | от 21 ₽ | ||
SN74LVC126ADR Texas Instruments | 33 ₽ | ||
SN74LVC126ADR | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LVC126A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 9.3,6.7,5,4.5 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC126A (22)
- SN74LVC126AD SN74LVC126ADBLE SN74LVC126ADBR SN74LVC126ADE4 SN74LVC126ADG4 SN74LVC126ADGVR SN74LVC126ADGVRE4 SN74LVC126ADR SN74LVC126ADRE4 SN74LVC126ADRG4 SN74LVC126ADT SN74LVC126ADTG4 SN74LVC126ANSR SN74LVC126APW SN74LVC126APWG4 SN74LVC126APWLE SN74LVC126APWR SN74LVC126APWRE4 SN74LVC126APWRG4 SN74LVC126APWT SN74LVC126ARGYR SN74LVC126ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
