Источники питания Keen Side
Datasheet Texas Instruments TPS65552ARGTT — Даташит
СерияTPS65552A
МодельTPS65552ARGTT
Встроенное зарядное устройство для фотовспышки и драйвер IGBT 16-QFN от -35 до 85
TPS65552ARGTT
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
МаркировкаBKV
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
RoHSНе совместим
  • Charging Photo-Flash Capacitors Using the TPS65552A
    PDF, 107 Кб, Файл опубликован: 5 июл 2006
    The TPS6555x family of devices are highly integrated flyback converters used to charge photo-flash capacitors. This document contains a reference design and an example of a PCB design using the TPS65552A.
  • Design For Integrated Photo Flash Charger and IGBT Driver
    PDF, 968 Кб, Файл опубликован: 21 окт 2005
    The Texas Instruments TPS65552A offers a complete solution for charging photo flash capacitors. It has an integrated power switch, an IGBT driver, and control logic block for photo flash applications. The TPS65552A controller requires only a few external components and gives fast charging times with high efficiency.
  • TPS65552A powers portable photoflash
    PDF, 146 Кб, Файл опубликован: 17 июл 2006
Серия: TPS65552A (3)
  • Semiconductors > Power Management > LED Driver > Camera Flash LED Driver
На английском языке: Datasheet Texas Instruments TPS65552ARGTT
