Datasheet Texas Instruments BQ24765RUVT — Даташит
СерияBQ24765
МодельBQ24765RUVT
Зарядное устройство, управляемое по SMBus, со встроенными полевыми транзисторами 34-VQFN от -40 до 155
bq24765 SMBus-Controlled Multi-Chemistry Battery Charger With Integrated Power MOSFETs datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 ноя 2015
43 предложений от 17 поставщиков
Микросхема Чип управления батареи, Battery Charge Management SMBus Controlled Battery Charger with Integrated FETs Battery Charger 8064mA 1.024V to 19.2V 34Pin...
727GS
BQ24765RUVT
от 89 ₽
BQ24765RUVT
от 175 ₽
ЭИК
BQ24765RUVT
от 1 077 ₽
BQ24765RUVT
от 1 460 ₽
Pin34
Package TypeRUV
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаBQ24765
Width (мм)7
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)19.2 В
Battery Charge Voltage(Min)1.024 В
Cell ChemistryLead Acid,Li-Ion/Li-Polymer,LiFePO4,NiCd,NiMH
Charge Current(Max)10 A
Control InterfaceSMBus
Control TopologySwitch-Mode Buck
Number of Series Cells2,3,4
Operating Vin(Max)24 В
Operating Vin(Min)7 В
Package GroupVQFN
Package Size: mm2:W x L34VQFN: 25 mm2: 7 x 3.5(VQFN) PKG
Special FeaturesIntegrated FET,Power Path,Thermal Regulation
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24765EVM
    BQ24765 Evaluation Module for SMBus Controlled Battery Charger with Integrated FETs
  • How to Review a Multicell Switching Charger Schematic
    PDF, 196 Кб, Файл опубликован: 21 сен 2011
    This application report provides a checklist for reviewing a switching charger schematic and explains each item in the list.
  • Operating Fuel Gauge bq20z7x/8x/9x and SMBus-Like bq24745/47/65 Chargers
    PDF, 132 Кб, Файл опубликован: 6 окт 2009
    The smart charger bq24747/765 is a high-efficiency, synchronous battery charger with an integrated input current comparator. This charger provides low component count for space constrained, multichemistry battery charging applications. SMBus input current, charge current, and input current digital-to-analog converters allow for very high regulation accuracies that the system power management micr
Серия: BQ24765 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24765RUVT
