Datasheet Texas Instruments UCC3810DWG4 — Даташит
СерияUCC3810
МодельUCC3810DWG4
Двухканальный режим синхронизации тока ШИМ 16-SOIC от 0 до 70
Dual Channel Synchronized Current Mode PWM datasheet
PDF, 727 Кб, Версия: D, Файл опубликован: 2 ноя 2004
Current Mode PWM Controller 1A 1000kHz 16Pin SOIC Tube
UCC3810DWG4
198 ₽
T-electron
UCC3810DWG4
268 ₽
UCC3810DWG4
585 ₽
HXD Co.
UCC3810DWG4
Pin16
Package TypeDW
Package QTY40
МаркировкаUCC3810DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Gate Drive(Typ)1 A
Special FeaturesError Amplifier,Leading Edge Blanking,Multi-topology,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off11.3/8.3 В
Vin(Max)11 В
Vin(Min)8.3 В
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 2
    PDF, 224 Кб, Файл опубликован: 28 фев 2005
    To conclude the review of the UCC28517 PFC supply, this article covers the design of the second 12-V, 8-W power stage to be used as an auxiliary bias supply.
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 1
    PDF, 202 Кб, Файл опубликован: 28 фев 2005
    Power factor corrected (PFC) preregulators are generally used in ac/dc converters operating above 75 W or to meet line harmonic requirements. This article reviews the design of a 100-W ac/dc power stage with PFC.
Серия: UCC3810 (5)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC3810DWG4
