Источники питания Keen Side
Datasheet Texas Instruments REF102BPG4 — Даташит
СерияREF102
МодельREF102BPG4
2.5ppm/В°C Drift, 10-V Precision Voltage Reference 8-PDIP
10V Precision Voltage Reference datasheet
PDF, 912 Кб, Версия: B, Файл опубликован: 16 июн 2009
Опорный чип напряжения, V-Ref Precision 10V 10mA 8Pin PDIP Tube
REF102BPG4
169 ₽
REF102BPG4
277 ₽
REF102BPG4
727GS
REF102BPG4
Pin88
Package TypePP
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
Package QTY5050
CarrierTUBETUBE
МаркировкаBREF102P
Width (мм)6.356.35
Length (мм)9.819.81
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Initial Accuracy(Max)0.1 %
Iout/Iz(Max)10 мА
Iq(Max)N/A uA
Iq(Typ)1400 uA
LFN 0.1-10Hz(Typ)5 ОјVpp
Рабочий диапазон температурот -25 до 85 C
Package GroupPDIP
Pin/Package8PDIP, 8SOIC
Special FeaturesN/A
Temp Coeff(Max)2.5,5,10 ppm/ degree C
VO10 В
Vin(Max)36 В
Vin(Min)11.4 В
  • Improved Voltage Reference Filter Has Several Advantages
    PDF, 31 Кб, Файл опубликован: 2 окт 2000
    The Burr-Brown REF102 is a buried-zener-based precision 10V reference. It has better stability and about five times lower output noise than band-gap-based voltage references such as the PMI REF-10. Still, its output noise is about 600uVp-p at a noise bandwidth of 1MHz (the output noise of the PMI REF-10 is about 3,000uVp-p at 1MHz).
  • Voltage-Reference Filters
    PDF, 25 Кб, Файл опубликован: 27 сен 2000
    The Burr-Brown REF102 is a buried-zener-based precision 10.0V reference. It has better stability and about five times lower output noise than band-gap-based voltage references such as the PMI REF-10. Still, its output noise is about 600uVp-p at a noise bandwidth of 1MHz (the output noise of the PMI REF-10 is about 3,000uVp-p at 1MHz).
  • Low Power Operation of REF102 10.0V Precision Voltage Reference
    PDF, 36 Кб, Файл опубликован: 2 окт 2000
    Two of the most important specifications for a voltage reference are noise and stability with time. The zener-based REF102 10.0V voltage reference has much better noise and stability than band-gap-based references.
  • The ACF2101 Used as a Bipolar Switched Integrator
    PDF, 35 Кб, Файл опубликован: 27 сен 2000
    The ACF2101 is a dual, switched integrator that is typically used to convert a positive input current to a negative output voltage by integration, using an integration capacitor (CINT), either on the chip or an external capacitor provided by the user. Typical applications for the ACF2101 are photo diode integrators, current measurements, charge measurements, and a CT scanner front end.
  • Make A Precision Current Source or Current Sink
    PDF, 26 Кб, Файл опубликован: 27 сен 2000
    The precision current source and sink are based on the new REF102 10.0V voltage reference. With 2.5ppm/В°C VOUT drift, and better than 5ppm/1000hrs long-term stability, this buried-zener-based voltage reference offers the best performance available from a single-chip voltage reference today. The REF200 uses a band-gap type reference to allow low-voltage two-terminal operation. This m
  • Make a Precision В± 10 V Reference
    PDF, 37 Кб, Файл опубликован: 2 окт 2000
    Many systems require the combination of both a positive and a negative precision 10.0V reference. ADI offers several hybrid В±10V references. Although Burr-Brown offers no В±10V reference at this time, we do have some simple two-chip solutions which are accurate and can be more cost effective.
  • Level Shifting Signals with Differential Amplifiers
    PDF, 23 Кб, Файл опубликован: 27 сен 2000
    The INA105 is a unity gain differential amplifier consisting of a premium grade operational amplifier and an on-chip precision resistor network. The self-contained INA105 makes it ideal for many applications. One such application is precision level shifting.
  • Design and analysis of a TGC circuit to drive the control voltage
    PDF, 488 Кб, Файл опубликован: 26 апр 2017
  • Make a Precision -10 V Reference (Rev. A)
    PDF, 87 Кб, Версия: A, Файл опубликован: 18 май 2015
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
На английском языке: Datasheet Texas Instruments REF102BPG4
