Datasheet Texas Instruments TPS54873PWP — Даташит
СерияTPS54873
МодельTPS54873PWP
Входное напряжение от 4,5 до 5,5 В, ток 8 А, синхронный понижающий преобразователь SWIFT™ для выходов с предсмещением 28-HTSSOP от -40 до 85
4-V to 6-V Input, 8-A Output Synchronous Buck Switcher datasheet
PDF, 701 Кб, Версия: A, Файл опубликован: 8 мар 2005
16 предложений от 11 поставщиков
TPS54873PWP
221 ₽
TPS54873PWP
232 ₽
T-electron
TPS54873PWP
680 ₽
HXD Co.
TPS54873PWP
771 ₽
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS54873
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Evaluation Modules & Boards: TPS54873EVM
    8-A, 5Vin DC/DC Converter with Disabled Sinking During Startup
  • Sequencing with TPS54x80 and TPS54x73 DC/DC Converters
    PDF, 169 Кб, Файл опубликован: 14 апр 2003
    Design of a power supply for a high-performance point-of-load processor requires special attention to manage core and input/output (I/O) voltage sequencing, which is critical to device operation and long term reliability. The TPS54x80 devices of low input voltage synchronous-buck dc/dc converters are designed for easily implementing sequential, ratio-metric, or simultaneous sequencing schemes. F
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54873 (3)
На английском языке: Datasheet Texas Instruments TPS54873PWP
