Datasheet Texas Instruments UCC27222PWPR — Даташит
СерияUCC27222
МодельUCC27222PWPR
Высокоэффективный синхронный понижающий драйвер с прогнозированием 14-HTSSOP от -40 до 105
High-Efficiency Predictive Synchronous Buck Driver datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 16 июл 2003
MOSFET DRVR 3.3A 2Out Hi/Lo Side Inv/Non-Inv 14Pin HTSSOP EP T/R
UCC27222PWPR
118 ₽
UCC27222PWPR
124 ₽
T-electron
UCC27222PWPR
162 ₽
UCC27222PWPR
428 ₽
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка27222
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bus Voltage30 В
Channel Input LogicTTL
Fall Time17 нс
Input ThresholdTTL
Input VCC(Max)20 В
Input VCC(Min)5 В
Negative Voltage Handling at HS Pin-0.3 В
Количество каналов2
Package GroupHTSSOP
Peak Output Current3 A
Power SwitchMOSFET
Prop Delay60 нс
Rise Time17 нс
Special FeaturesDead Time Control,Soft Switching,Synchronous Rectification
  • Increasing UCC27221/2 Gate Drive Voltage
    PDF, 85 Кб, Файл опубликован: 20 июн 2003
    The UCC2722x contains an internal 6.5-V regulator, from which the gate drive voltages for the high and low-side MOSFETs of a synchronous buck power stage are derived. In some instances it may be desirable to drive the MOSFET gates with a voltage other than 6.5 V. The output driver stage of the UCC2722x has an absolute maximum voltage rating of 10 V. However it is still possible to bypass the inter
  • Low Voltage Feedback in PWM Applications
    PDF, 56 Кб, Файл опубликован: 27 фев 2003
    Normally the output voltage of a switching power supply is higher than the error amplifier reference, and so a simple resistive divider between the output voltage and ground at the non-inverting input of the PWM error amplifier is all that is required to set the regulation voltage. However, when the output voltage is less than the error amplifier reference voltage, the feedback voltage must be div
  • Predictive Gate Drive (tm) FAQ
    PDF, 152 Кб, Файл опубликован: 3 фев 2003
    The proprietary Predictive Gate Driveв„ўtechnology from Texas Instruments maximizes efficiencies of today's high frequency, low output voltage, synchronous buck converters. To gain a better understanding of this innovative new control technique, this list of frequently asked questions (FAQs) addresses the Predictive Gate Driveв„ў technique.
  • Predictive Gate Drive Boosts Converter Efficiency
    PDF, 376 Кб, Файл опубликован: 18 дек 2002
    Predictive Gate Driveв„ў is a novel digital control-driven technique that optimizes MOSFET turn-on and turn-off delays in synchronous rectifiers. It uses a closed loop feedback system to detect body-diode conduction, and continuously adjusts dead-time delays to minimize the conduction time interval. Depending upon operating frequency and output voltage, the Predictive Gate Driveв„ў control
  • UCC27221/2 Predictive Gate Drive FAQ
    PDF, 211 Кб, Файл опубликован: 18 дек 2002
    The UCC27221/2 High-Efficiency Predictive Synchronous Buck Driver from Texas Instruments, employs the proprietary Predictive Gate Driveв„ў technology to maximize efficiencies of today's high frequency, low output voltage, synchronous buck converters. To gain a better understanding of this innovative new control technique, a list of frequently asked questions (FAQs) has been developed to addres
Серия: UCC27222 (3)
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Half-bridge Driver
На английском языке: Datasheet Texas Instruments UCC27222PWPR
