Источники питания Keen Side
Datasheet Texas Instruments TLV2361CDBV — Даташит
СерияTLV2361
МодельTLV2361CDBV
Одиночный высокопроизводительный низковольтный операционный усилитель 5-SOT-23 0–70
High-Performance Low-Voltage Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 июн 2007
Микросхема Буферный усилитель, IC OPAMP GP 7MHz SOT23-5
TLV2361CDBV
20 ₽
TLV2361CDBV
66 ₽
TLV2361CDBV
от 138 ₽
TLV2361CDBV
Pin5
Package TypeDBV
Industry STD TermSOT
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Рекомендуемая замена
ReplacementTLV2361CDBVR
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)0.29 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)85
CMRR(Typ)(dB)60
GBW(Typ)(MHz)7
Input Bias Current(Max)(pA)150000
Iq per channel(Max)(mA)2.5
Iq per channel(Typ)(mA)1.75
Number of Channels(#)1
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)1.2
Package GroupSOT-23
Package Size: mm2:W x L (PKG)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Rail-to-RailNo
Slew Rate(Typ)(V/us)3
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2
Vn at 1kHz(Typ)(nV/rtHz)8
Vos (Offset Voltage @ 25C)(Max)(mV)6
RoHSНе совместим
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
На английском языке: Datasheet Texas Instruments TLV2361CDBV
