Datasheet Texas Instruments OPA2364AIDGKTG4 — Даташит
Серия | OPA2364 |
Модель | OPA2364AIDGKTG4 |
1,8 В, высокий CMR, операционный усилитель RRIO 8-VSSOP от -40 до 125
OPAx363, OPAx364 1.8-V, 7-MHz, 90-dB CMRR, Single-Supply, Rail-to-Rail I/O Operational Amplifier datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 6 мар 2016
![]() 15 предложений от 13 поставщиков Микросхема Операционный усилитель, OP Amp Dual GP R-R I/O ±2.75V/5.5V 8Pin VSSOP T/R | |||
OPA2364AIDGKTG4 Texas Instruments | 169 ₽ | ||
OPA2364AIDGKTG4 Texas Instruments | от 176 ₽ | ||
OPA2364AIDGKTG4 | по запросу | ||
OPA2364AIDGKTG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | BHL |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | Shutdown |
Архитектура | CMOS |
CMRR(Min) | 74 дБ |
CMRR(Typ) | 90 дБ |
GBW(Typ) | 7 МГц |
Input Bias Current(Max) | 10 pA |
Iq per channel(Max) | 0.75 мА |
Iq per channel(Typ) | 0.65 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 3 uV/C |
Output Current(Typ) | 45 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 5 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 1.8 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 17 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 2.5 мВ |
- High-Voltage Signal Conditioning for Differential ADCsPDF, 125 Кб, Файл опубликован: 14 июн 2004
Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design, - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2364 (16)
