Datasheet Linear Technology LTC1150CS8#TRPBF — Даташит
СерияLTC1150
МодельLTC1150CS8#TRPBF
Рабочий усилитель с нулевым дрейфом ± 15 В и внутренними конденсаторами
Datasheet LTC1150
PDF, 245 Кб, Язык: анг., Файл закачен: 31 июл 2016, Страниц: 16
±15V Zero-Drift Operational Amplifier with Internal Capacitors
36 предложений от 16 поставщиков
727GS
LTC1150CS8#TRPBF
от 205 ₽
LTC1150CS8#TRPBF
от 215 ₽
IC Home
LTC1150CS8#TRPBF
996 ₽
ЭИК
LTC1150CS8#TRPBF
от 1 502 ₽
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW2.5 МГц
Av Min Stable1 V/V
Avol120 дБ
CMRR130 дБ
Cload100 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Экспортный контрольнет
Ibias0.01 нА
Inoise0.0018 пА/rtГц
Ios0.00002 мкА
Iout12 мА
Isupply0.8 мА
LF Enoise1.8 µVPP
Over-the-Topнет
PSRR145 дБ
Rail-to-RailIn to V-
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR3 В/мс
Shutdownда
Single Supplyда
ТипZD
VinCM High (from V+)0.003 В
Voh (from V+)0.05 В
Vol (from V-)0.05 В
Vos0.0005 мВ
Vos TC0.01 мВ/C
Vs макс.32 В
Vs мин.4.75 В
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Measurement and Control Circuit Collection &mdash AN45
    PDF, 1.2 Мб, Файл опубликован: 5 июн 1991
    A variety of measurement and control circuits are included in this application note. Eighteen circuits, including ultra low noise amplifiers, current sources, transducer signal conditioners, oscillators, data converters and power supplies are presented. The circuits emphasize precision specifications with relatively simple configurations.
  • A Collection of Differential to Single-Ended Signal Conditioning Circuits for Use with the LTC2400, a 24-Bit No Latency Delta Sigma ADC in an SO-8 &mdash AN78
    PDF, 177 Кб, Файл опубликован: 7 авг 1999
    This application note describes six low power differential-tosingle- ended signal conditioning circuits for the LTC2400 No Latency ΔΣTM 24-bit ADC. These circuits offer the customer a number of choices for conditioning differential input signals as low as 5mV to as high as ±2.5V, as well as operation on a single 5V or ±5V supplies. Each circuit description also covers circuit design and implementation techniques that can help preserve the LTC2400's inherently high effective resolution. AN78 concludes with two circuits for digitizing temperature when using an RTD or Type S thermocouple.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Low Bias Current Amplifiers (Ib < 100pA) | High Voltage Amplifiers (>12V) | Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp)
LTC1150CS8TRPBF, LTC1150CS8 TRPBF
На английском языке: Datasheet Linear Technology LTC1150CS8#TRPBF
