Datasheet NCP2892AFCT2G - ON Semiconductor Даташит Аудио усилители ANA BUMP моно PWR усилитель — Даташит
Наименование модели: NCP2892AFCT2G
18 предложений от 17 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 1.08W Class-AB 9Pin Flip-Chip T/R
727GS
NCP2892AFCT2G
от 15 ₽
IC Home
NCP2892AFCT2G
16 ₽
NCP2892AFCT2G
NCP2892AFCT2G
Производитель: ON Semiconductor
Описание: Аудио усилители ANA BUMP моно PWR усилитель
datasheetСкачать DataSheet
NCP2892 Series 1.3 Watt Audio Power Amplifier with Fast Turn On Time
The NCP2892 is an audio power amplifier designed for portable communication device applications such as mobile phone applications.
The NCP2892 is capable of delivering 1.3 W of continuous average power to an 8.0 W BTL load from a 5.0 V power supply, and 1.0 W to a 4.0 W BTL load from a 3.6 V power supply. The NCP2892 provides high quality audio while requiring few external components and minimal power consumption. It features a low-power consumption shutdown mode, which is achieved by driving the SHUTDOWN pin with logic low. The NCP2892 contains circuitry to prevent from "pop and click" noise that would otherwise occur during turn-on and turn-off transitions. For maximum flexibility, the NCP2892 provides an externally controlled gain (with resistors), as well as an externally controlled turn-on time (with the bypass capacitor). When using a 1 mF bypass capacitor, it offers 100 ms wake up time. Due to its excellent PSR
  • Вид монтажа: SMD/SMT
  • Входной сигнал: Differential or Single
  • Выходная мощность: 1.08 Вт
  • Выходной сигнал: Differential
  • Диапазон напряжения питания: 2.2 В ... 5.5 В
  • Источник питания: Single
  • Максимальное рассеяние мощности: 650 мВт
  • Продукт: Class-AB
  • Рабочее напряжение питания: 3 В, 5 В
  • Сопротивление аудио нагрузки: 8 Ом
  • Суммарные нелинейные искажения + шум: 0.02 %
  • Тип выхода: 1-Channel Mono
  • Тип корпуса: WLCSP-9
  • Упаковка: Reel
  • RoHS: да
На английском языке: Datasheet NCP2892AFCT2G - ON Semiconductor Audio Amplifiers ANA BUMP MONO PWR AMP
