Клеммные колодки Keen Side
Datasheet ATMEGA8A-PN - Atmel Даташит Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 1 Кб SRAM-16MHz 105C — Даташит
Наименование модели: ATMEGA8A-PN
22 предложений от 14 поставщиков
ATMEGA8A-PN
164 ₽
T-electron
ATMEGA8A-PN
233 ₽
ATMEGA8A-PN
от 572 ₽
ATMEGA8A-PN
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 1 Кб SRAM-16MHz 105C
data sheetСкачать Data Sheet
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 130 Powerful Instructions ­ Most Single-clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 8K Bytes of In-System Self-programmable Flash program memory ­ 512 Bytes EEPROM ­ 1K Byte Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation ­ Programming Lock for Software Security Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler, one Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Real Time Counter with Separate Oscillator ­ Three PWM Channels ­ 8-channel ADC in TQFP and QFN/ML
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA8APN, ATMEGA8A PN
На английском языке: Datasheet ATMEGA8A-PN - Atmel Microcontrollers (MCU) AVR 8 Kb FLSH 512B EE 1 Kb SRAM-16MHz 105C
