Datasheet ATMEGA168P-20ANR - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz 105C — Даташит
Наименование модели: ATMEGA168P-20ANR
Микросхема Микроконтроллер, MCU 8Bit ATmega AVR RISC 16KB Flash 3.3V/5V 32Pin TQFP T/R
T-electron
ATMEGA168P-20ANR
276 ₽
ATMEGA168P-20ANR
Atmel
319 ₽
ATMEGA168P-20ANR
ATMEGA168P-20ANR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz 105C
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel® AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16K Bytes of In-System Self-Programmable Flash progam memory ­ 256/512/512 Bytes EEPROM ­ 512/1K/1K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Real Time Counter with Separate Oscillator ­ Six PWM Channels ­ 8-channel 10
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA168P20ANR, ATMEGA168P 20ANR
На английском языке: Datasheet ATMEGA168P-20ANR - Atmel Microcontrollers (MCU) AVR 16 Kb FL 512B EE 1 Kb SRAM-20MHz 105C
