Datasheet JVN1A-5V-FJ - Panasonic Даташит Реле, PCB, SPNO, 16 А, 5 В постоянный ток — Даташит
Наименование модели: JVN1A-5V-FJ
Купить JVN1A-5V-FJ на РадиоЛоцман.Цены — от 584 до 704 ₽ General Purpose Relay, JV-N Series, Power, Non Latching, SPST-NO, 5VDC, 16A | |||
JVN1A-5V-FJ Panasonic | 584 ₽ | ||
JVN1A-5V-FJ Panasonic | 704 ₽ |
Производитель: Panasonic
Описание: Реле, PCB, SPNO, 16 А, 5 В постоянный ток
JV-N
COMPACT FLAT POWER RELAY FOR HEATER LOADS
JV-N RELAYS
COMMENTS ABOUT Cd FREE
We have introduced Cadmium free type products to reduce the material which is not good for our environment.
(The suffix "F" should be added to the part number.) If you are still using Cadmium containing parts, which don't have "F" on the suffix of the part number, please use Cadmium free parts from now on. The life of the Cadmium free parts may be shorter than the Cadmium containing parts based on the load condition, so please evaluate the Cadmium free parts with your actual application before use.
- Coil Current: 44.4 мА
- Coil Resistance: 101 Ом
- Coil Type: DC
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 125 В
- Contact Voltage DC Nom: 30 В
- External Depth: 22 мм
- Operating Power Nom: 200 мВт
- Внешняя ширина: 16 мм
- Габариты: высота: 10.5 мм
- Конфигурация контактов: SPST-NO
- Способ монтажа: PCB
- Тип реле: Power
- RoHS: да
- SVHC: No SVHC (19-Dec-2011)
JVN1A5VFJ, JVN1A 5V FJ
