Datasheet G7L-2A-P 24DC - Omron Даташит Реле, PCB, DPST-NO, 20 А, 24 В постоянный ток — Даташит
Наименование модели: G7L-2A-P 24DC
Купить G7L-2A-P 24DC на РадиоЛоцман.Цены — от 1 099 до 125 074 ₽ 7 предложений от 7 поставщиков Power Relay 24VDC 20A DPST-NO (( 52.5mm 35.5mm 47mm)) Through Hole | |||
G7L2AP24DC Omron | 1 099 ₽ | ||
G7L2AP24DC Omron | 1 373 ₽ | ||
G7L-2AP-24DC Omron | по запросу | ||
G7L2AP24DC Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, DPST-NO, 20 А, 24 В постоянный ток
General Purpose Relay
G7L
· Ideally suited for high-inrush fluid pump controls: pool/spa, water processing, emergency, chemical industry, etc.
· High-capacity, high-withstand voltage relay with no contact chattering for momentary voltage drops up to 50% of rated voltage. · UL Class B construction standard. · Wide-range AC-activated coil that handles 100 to 120 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching capacity, particularly for inductive loads. · Flame resistant materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals available. · Standard models are UL, CSA, and TUV approved; VDE/IEC 950 versions are now available. Meet pollution degree 3, Material Group II & III.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., G7L-1A-T-CB-AC100/120). Type E bracket (see note 1) E bracket (see note 1) (with test button) Upper bracket Upper bracket (with test button) PCB mou
- Coil Current: 79 мА
- Coil Resistance: 303 Ом
- Coil Type: DC
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 20 А
- External Depth: 52.5 мм
- Operating Power Nom: 1.9 Вт
- Внешняя ширина: 35.5 мм
- Габариты: высота: 41 мм
- Конфигурация контактов: DPST-NO
- Способ монтажа: PCB
- Тип реле: General Purpose
- RoHS: да
- SVHC: No SVHC (19-Dec-2011)
G7L2AP 24DC, G7L 2A P 24DC
