Datasheet SSM2518CBZ-R7 - Analog Devices Даташит Усилитель, аудио, 16WLCSP — Даташит
Наименование модели: SSM2518CBZ-R7
Купить SSM2518CBZ-R7 на РадиоЛоцман.Цены — от 149 до 665 ₽ 28 предложений от 14 поставщиков Интегральные микросхемы Линейные микросхемы - Усилители - Звуковые | |||
SSM2518CBZ-R7 Analog Devices | 149 ₽ | ||
SSM2518CBZ-R7 Rochester Electronics | от 176 ₽ | ||
SSM2518CBZ-R7 Analog Devices | 316 ₽ | ||
SSM2518CBZ-R7 Analog Devices | 465 ₽ |
Производитель: Analog Devices
Описание: Усилитель, аудио, 16WLCSP
Data Sheet
FEATURES
Filterless, digital input Class-D amplifier Serial digital audio interface supports common formats I2S, left justified, right justified, TDM1-16, and PCM 2 channels Ч 2 W into 4 and 2 channels Ч 1.4 W into 8 with 1% THD+N, when using a 5 V supply I2C control interface or standalone operation 91% efficiency at full scale into an 8 load 97 dB signal-to-noise ratio (SNR), A-weighted 80 dB power supply rejection ratio (PSRR) at 217 Hz Digital volume control: -71.25 dB to +24 dB in 0.375 dB steps Supports a wide range of sample rates from 8 kHz to 96 kHz Automatic sample rate detection Can operate using 64 Ч fS BCLK as the MCLK source 2.5 V to 5.5 V speaker supply voltage (PVDD) 1.62 V to 3.6 V digital supply voltage (DVDD) Pop-and-click suppression Short-circuit and thermal protection with programmable autorecovery Smart power-down when no input signal is detected Power-on reset Low power modes for performance/power trade-offs User selectable ultralow EMI emission mo
- Класс усилителя: D
- Количество каналов: 2
- Выходная мощность: 2 Вт
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: -40°C ...
+85°C
- Тип корпуса: WLCSP
- Количество выводов: 16
- SVHC: No SVHC (20-Jun-2011)
SSM2518CBZR7, SSM2518CBZ R7
