Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet AT32UC3C264C-A2UT - Atmel Даташит Микроконтроллеры (MCU) UC3C 64K FLASH 16K SRAM — Даташит
Atmel AT32UC3C264C-A2UT
Наименование модели: AT32UC3C264C-A2UT
24 предложений от 15 поставщиков
LIXINC Electronics
AT32UC3C264C-A2UT
от 27 ₽
AT32UC3C264C-A2UT
428 ₽
T-electron
AT32UC3C264C-A2UT
658 ₽
AT32UC3C264C-A2UT
Atmel
756 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3C 64K FLASH 16K SRAM
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 91 DMIPS Running at 66 MHz from Flash (1 Wait-State) · Up to 49 DMIPS Running at 33 MHz from Flash (0 Wait-State) ­ Memory Protection Unit Multi-hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash ­ 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions ­ Single Cycle Access up to 33 MHz ­ FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Int
  • Шина данных: 32 бит
  • RoHS: да
AT32UC3C264CA2UT, AT32UC3C264C A2UT
На английском языке: Datasheet AT32UC3C264C-A2UT - Atmel Microcontrollers (MCU) UC3C 64K FLASH 16K SRAM
