Datasheet SSM2804CBZ-RL - Analog Devices Даташит ИС, аудио усилитель — Даташит
Наименование модели: SSM2804CBZ-RL
Купить SSM2804CBZ-RL на РадиоЛоцман.Цены — от 162 до 295 ₽ 15 предложений от 12 поставщиков ANALOG DEVICES SSM2804CBZ-RL Audio Power Amplifier, D, 2Channel, 1.4W, 2.5V to 3.6V, WLCSP, 30Pins | |||
SSM2804CBZ-RL Analog Devices | от 162 ₽ | ||
SSM2804CBZ-RL Analog Devices | 205 ₽ | ||
SSM2804CBZ-RL Analog Devices | по запросу | ||
SSM2804CBZ-RL | по запросу |
Производитель: Analog Devices
Описание: ИС, аудио усилитель
Audio Subsystem with Class-D Speaker and Capless Headphone Driver SSM2804
FEATURES
3 single-ended stereo audio inputs with optional differential mode Stereo, 1.4 W, filterless Class-D amplifiers with - modulation Integrated receiver path bypass switch Configurable, high performance capless headphone output with true ground Class-G technology Optional hardware-based headphone level limiter I2C control interface Volume control Flexible input/output mixing Output mode control EMI emissions control Automatic level control (ALC) Adjustable headphone level limiter Low shutdown current Short-circuit and thermal protection Pop-and-click suppression Available in a 30-ball, 2.5 mm Ч 3.0 mm WLCSP
Each set of inputs is independently adjustable with the 2-wire I2C interface and features an adjustable gain over a 30 dB range in steps of 1 dB.
Each set of input channels also offers the choice of variable input impedance PGA mode or fixed input impedance boost mode. The input signals are then mixed a
- Выходная мощность: 1.4 Вт
- Диапазон напряжения питания: 2.5 В ... 3.6 В
- Класс усилителя: D
- Количество выводов: 30
- Количество каналов: 2
- Рабочий диапазон температрур: -40°C ... +85°C
SSM2804CBZRL, SSM2804CBZ RL
