Datasheet MAX3380ECUP+ - Maxim Даташит ИС, RS-232 TXRX, 460KBPS, 5.5 В, TSSOP-20 — Даташит
Maxim MAX3380ECUP+
Наименование модели: MAX3380ECUP+
28 предложений от 20 поставщиков
Приемопередатчик RS-232 2Tx/2Rx, +2.35В до +5.5В, 1мкА, I/O с защитой от ЭСР ±15кВ, TSSOP-20
T-electron
MAX3380ECUP+
Maxim
335 ₽
MAX3380ECUP+
Maxim
474 ₽
MAX3380ECUP+
Maxim
от 1 555 ₽
MAX3380ECUP+T
Производитель: Maxim
Описание: ИС, RS-232 TXRX, 460KBPS, 5.5 В, TSSOP-20
data sheetСкачать Data Sheet
19-2128; Rev 0; 8/01
+2.35V to +5.5V, 1µA, 2Tx/2Rx RS-232 Transceivers with ±15kV ESD-Protected I/O and Logic Pins MAX3380E/MAX3381E
General Description
The MAX3380E/MAX3381E are +2.35V to +5.5V-powered EIA/TIA-232 and V.28/V.24 communication interfaces with low power requirements, high data-rate capabilities, and enhanced electrostatic discharge (ESD) protection on both the TTL and RS-232 sides.
The MAX3380E/MAX3381E have two receivers and two transmitters. All RS-232 inputs, outputs, and logic input pins are protected to ±15kV using IEC 1000-4-2 AirGap Discharge method and the Human Body Model, and ±8kV using IEC 1000-4-2 Contact Discharge method. The proprietary low-dropout transmitter output stage enables true RS-232 performance from a +3.1V to +5.5V supply with a dual charge pump. The parts reduce the transmitter output levels to RS-232-compatible levels with no increase in supply current for supplies less than +3.1V and greater than +2.35V. The +2.35V to +5.5V operating range is
  • Device Type: Transceiver
  • IC Interface Type: RS232
  • Количество драйверов: 2
  • Диапазон напряжения питания: 2.35 В ... 5.5 В
  • Тип корпуса: TSSOP
  • Количество выводов: 20
  • Рабочий диапазон температрур: 0°C ... +70°C
На английском языке: Datasheet MAX3380ECUP+ - Maxim IC, RS-232 TXRX, 460KBPS, 5.5 V, TSSOP-20
