Источники питания Keen Side
Datasheet LTC2633CTS8-HZ8 - Linear Technology Даташит — Даташит
Наименование модели: LTC2633CTS8-HZ8
18 предложений от 13 поставщиков
DUAL 8-BIT I2C VOUT DAC / 8 Bit Digital to Analog Converter 2 TSOT-23-8
LTC2633CTS8-HZ8#TRPBF
123 ₽
IC Home
204 ₽
LTC2633CTS8-HZ8#TRMPBF
411 ₽
LTC2633CTS8-HZ8 PBF
Производитель: Linear Technology
data sheetСкачать Data Sheet
Features
n
LTC2633 Dual 12-/10-/8-Bit I2C VOUT DACs with 10ppm/°C Reference Description
The LTC®2633 is a family of dual 12-, 10-, and 8-bit voltage-output DACs with an integrated, high accuracy, low drift reference in an 8-lead TSOT-23 package.
It has rail-to-rail output buffers and is guaranteed monotonic. The LTC2633-L has a full-scale output of 2.5V, and operates from a single 2.7V to 5.5V supply. The LTC2633-H has a full-scale output of 4.096V, and operates from a 4.5V to 5.5V supply. Each DAC can also operate with an external reference, which sets the full-scale output to the external reference voltage. These DACs communicate via a 2-wire I2C-compatible serial interface. The LTC2633 operates in both the standard mode (clock rate of 100kHz) and the fast mode (clock rate of 400kHz). The LTC2633 incorporates a power-on reset circuit. Options are available for reset to zero-scale, reset to mid-scale in internal reference mode, reset to mid-scale in external reference mode, or reset
  • Разрешение: 8 бит
  • Input Channel Type: Serial
  • Data Interface: 2-Wire, I2C, Serial
  • Supply Voltage Range - Analog: 4.5 В ... 5.5 В
  • Ток потребления: 500 мкА
  • Тип корпуса: TSOT-23
  • Количество выводов: 8
LTC2633CTS8HZ8, LTC2633CTS8 HZ8
На английском языке: Datasheet LTC2633CTS8-HZ8 - Linear Technology
