Datasheet LTC2632CTS8-HZ10 - Linear Technology Даташит — Даташит
Наименование модели: LTC2632CTS8-HZ10
Купить LTC2632CTS8-HZ10 на РадиоЛоцман.Цены — от 182 до 691 ₽ 19 предложений от 10 поставщиков Интегральные микросхемы Сбор данных — ЦАП | |||
LTC2632CTS8-HZ10#TRMPBF Analog Devices | 182 ₽ | ||
LTC2632CTS8-HZ10#TRPBF Analog Devices | 257 ₽ | ||
LTC2632CTS8-HZ10#TRMPBF Analog Devices | по запросу | ||
LTC2632CTS8-HZ10#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
FEATURES
n
LTC2632 Dual 12-/10-/8-Bit SPI VOUT DACs with 10ppm/°C Reference DESCRIPTION
The LTC®2632 is a family of dual 12-, 10-, and 8-bit voltageoutput DACs with an integrated, high-accuracy, low-drift reference in an 8-lead TSOT-23 package.
It has rail-to-rail output buffers and is guaranteed monotonic. The LTC2632-L has a full-scale output of 2.5V, and operates from a single 2.7V to 5.5V supply. The LTC2632-H has a full-scale output of 4.096V, and operates from a 4.5V to 5.5V supply. Each DAC can also operate with an external reference, which sets the full-scale output to the external reference voltage. These DACs communicate via a simple SPI/MICROWIRE compatible 3-wire serial interface which operates at clock rates up to 50MHz. The LTC2632 incorporates a power-on reset circuit. Options are available for reset to zero-scale or reset to mid-scale in internal reference mode, or reset to mid-scale in external reference mode after power-up.
L, LT, LTC, LTM, Linear Technology and the
- Разрешение: 10 бит
- Input Channel Type: Serial
- Data Interface: 3-Wire, Serial
- Supply Voltage Range - Analog: 4.5 В ... 5.5 В
- Ток потребления: 500 мкА
- Тип корпуса: TSOT-23
- Количество выводов: 8
LTC2632CTS8HZ10, LTC2632CTS8 HZ10
