Datasheet HSMS-2850-TR1G - Avago Technologies Даташит Диод, ВЧ, Шоттки, SOT-23 — Даташит
Наименование модели: HSMS-2850-TR1G
![]() 15 предложений от 15 поставщиков Диоды Шоттки, BROADCOM LIMITED HSMS-2850-TR1G RF Schottky Diode, Zero Bias, Single, 2V, 1mA, 250mV, 0.3pF, SOT-23 | |||
HSMS-2850-TR1G Broadcom | 27 ₽ | ||
HSMS-2850-TR1G Broadcom | 36 ₽ | ||
HSMS-2850-TR1G Broadcom | 58 ₽ | ||
HSMS-2850-TR1G | по запросу |
Производитель: Avago Technologies
Описание: Диод, ВЧ, Шоттки, SOT-23
HSMS-285x Series
Surface Mount Zero Bias Schottky Detector Diodes
Data Sheet
Description
Avago's HSMS-285x family of zero bias Schottky detector diodes has been designed and optimized for use in small signal (Pin < -20 dBm) applications at frequencies below 1.5 GHz.
They are ideal for RF/ID and RF Tag applications where primary (DC bias) power is not available. Important Note: For detector applications with input power levels greater than 20 dBm, use the HSMS-282x series at frequencies below 4.0 GHz, and the HSMS-286x series at frequencies above 4.0 GHz. The HSMS-285x series IS NOT RECOMMENDED for these higher power level applications. Available in various package configurations, these detector diodes provide low cost solutions to a wide variety of design problems. Avago's manufacturing techniques assure that when two diodes are mounted into a single package, they are taken from adjacent sites on the wafer, assuring the highest possible degree of match.
- Diode Configuration: Single
- Прямой ток максимальный: 1 мА
- Forward Voltage VF Max: 250 мВ
- Capacitance Ct: 0.3 пФ
- Тип корпуса: SOT-23
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Маркировка: P0
- Diode Type: RF Schottky
- Forward Current If(AV): 150 мА
- Forward Voltage: 250 мВ
- Рассеиваемая мощность максимальная: 75 мВт
- Repetitive Reverse Voltage Vrrm Max: 2 В
- Reverse Voltage Vr Max: 2 В
- Ширина ленты: 8 мм
- Способ монтажа: SMD
- Thermal Capacitance Ct: 0.3 пФ
- SMD Marking: P0
Дополнительные аксессуары:
- Electrolube - SMA10SL
- Roth Elektronik - RE901
HSMS2850TR1G, HSMS 2850 TR1G
